My 4770k does 4.4GHz in 1.28Vcore. Just wondering if delidding would do any good. Im not comfortable pushing it above 1.30V.
Would the decrease in load temp reduce the needed voltage to maintain that freq? thx
How hot is your chip getting, and what cooler are you using? Could just go to a better cooler if you're temp-limited. Taking off the IHS wouldn't be my first recommendation.
I don't know if reduced temp would impact your voltage requirement. Might have zero effect.
That really depends on how much the temps are decreased by delidding.
Back in the day when I delidded my Opteron 170, it decreased lead temps by 15c. I was able to overclock higher at the same voltage, which means I should have been able to lower the voltage and maintain the same overclock.
im using a corsair h110. Under stress test temps in the high 80s low 90s. Ive heard a lot of good comments regarding delidding the cpu. I just dont feel comfortable voiding the warranty for nothing.
