oOo sam lee oOo
- Aug 29, 2004
here are my comp specs:
2.8ghz p4 533mhz fsb..@..3.0(about).....northwood, btw
Mobo: ECS L4VXA2
RAM: Corsair ValueSelect 512mb pc3200
videocard: powercolor ati 9600se
and i dont think anything else might matter.
my..um...front side bus number thingy, (where you multiply that by 4, and it gives you the fsb...forgot wat it was called...) is at 142, and my mobo'll let me go to 162(or 165, i forgot)..when i go into Sisoftware sandra, it says my cpu is around 31-33 degrees C. i wanna get the number up to 152, so my cpu'll be around 3.2ghz. im using the stock heatsink right now, so would it be safe to do this(temp-wise)? and would any other components be affected?
Mobo: ECS L4VXA2
