Is it really worth Spending on DVI Cable
maverick786us
I am using Dell SP2208WFP connecting with an HD4850 using a VGA cable. Recently I read some reaviews that with a DVI cable its a brand new experience in gaming and movies. So my question is, "Is it really worth to get a DVI cable?". What all benifits will have with a DVI cable over standard VGA cable??
I have the same question actually: I have a 22'' lg l227wtg pf and am thinking about buying an dvi cable to hook it up to my 4870. worth it?
DVI is far better than VGA. I can't wait for monitors to stop coming with VGA ports. :D
How come only online retailers sell DVI cables at a decent price? Microcenter and circuit city have them for like 50-70 dollars
Those stores are a rip off for cables. I would check a small computer store if you have one near your area, they can sell you a DVI cable at a more decent price. Or, just buy it online.
My dad has a Gateway FHD2400, it was initially hooked up via VGA cable to a MSI NX8500GT. I wanted to see if there was a difference in picture quality between a VGA and DVI cable so I found the DVI cable that came with the monitor and was pleasantly suprised. The images looked alot more crisp and sharper, and the colors were more refined. Since noticing the difference I have been itching to connect my monitor to my MSI RX800 via DVI, except that my monitor doesn't have a DVI connection, which is why i'm getting a Lenovo L222 22" widescreen LCD for Christmas. Better contrast ratio, better response time, bigger screen, better looks, and hopefully better picture quality and better performance.
OK thanks for the suggestion I will purchase one DVI cable. Should I go for all DVI cables give almost the same output??
Seriously DVI cables are super cheap and yes just go with a cheap cable off of some place like newegg.
Don't do it! Think of all the other things you could get for TEN dollars. mmmm...doughnuts... Clean, clear, sharp text on a LCD monitor is overrated. That fuzzy VGA signal is so nostalgic after you turn the monitor off and the eye strain subsides. It's like computing in another century.
Lots of people pay pennies for the vintage computing experience. But you can have it by not doing anything. Oh and you have to get rid of that 4850. Historically inaccurate. I'll give you ten bucks for it. ;)
Let's look what is going on here with an LCD moniter.
VGA: Picture starts out as digital in your video card. Video card converts it to analog and sends it out the VGA cable. Montior receives the signal and converts it to digital to display it. So we have a conversion: Digital -> Analog -> Digital.
With DVI, it is just Digital -> Digital. There is no conversion and the video card can actually address each individual pixel on the screen.
DVI is _easily_ worth the $10 for the monoprice cable.
As long as the signal gets to the monitor without being corrupted there will be no picture difference, the ones and zeros will be the same information, doesn't matter if they went through 1 or 100 dollars of metal.
You'll need a normal "single-link" DVI cable "dual-link" is only necessary for 30'' monitors with higher resolution than 1920x1200.
With your monitor resolution the cheapest option should be more than sufficient.
Finally I got a DVI cable and plugged it. But I don't see any difference in the display. Do I have to change the settings or something??
Only if you arent running at the native res of the display.
It may be that you had a perfectly acceptable picture on VGA in the first place.
I've never noticed anything significant between vga and dvi on cards and displays when you can use either
I have this monitor now HP w2228h, if i use a cable dvi--»hdmi can i be limited to 30fps?
HDMI carries audio and offers some additional features over DVI. DVI is pin-compatible with HDMI, though. So, it is easy to hook up a DVI video card to an HDMI monitor and vice-versa.
DVI and HDMI are the only ways to go, my third monitor I had running on VGA and lemme just say the my screen looked like I should return it! I could see lines in the monitor with anything white behind it and flat out not use the monitor, swapped video cards with Dual DVI and haven't had an issue since.
VGA is old and not suited for todays machines or anything above say 1280, I run at 1920 x 1200 and saw the difference night and day.
ive gone from a 20" samsung dvi monitor,to a hp w2007,vga only monitor,and the picture looks sharper than the dvi samsung.so id say they are both the same.
Its worth it.
I own the same monitor, and when I hook my laptop up to it, I use VGA, and I can tell a difference.
A cable should have been included when you bought it, so if it wasn't included, call dell, and they should send you one. If you lost the one that was included, just spend 10.00 on a new one.
Yes, DVI is very much worth while, as long as you don't buy in a major retailer. (best buy, circuit city,ect.) These and hdmi are way overpriced at these stores for whatever ripoff of a reason
You ain't lying. When I was building my HT I needed 4 HDMI cables of varying lengths, CC wanted like $50 just for one of them, I doubt I paid that much for all 4 of them from monoprice.com
