Is it possible to repair?
XorCist
OMFG i am so pissed...the stupid pencil sharpener fell off the top of my desk bounced and hit my monitor..(19" LCD) and it took the black off the screen...is there any way to fix this? it is driving me insane and its in the lower middle of the screen, so i will always see it...please help
No idea what you're talking about. The casing is damaged? Do you have a picture?
It looks like you have ripped the Anti Glare (AG) filter.
They can be replaced by professional companies and you 'can' do it yourself but wouldnt recommend it.
An alternative is to glue it down as best as possible.
The glue holding it is water soluble in case that helps.
I do NOT advise trying to wet the glue on the LCD unless you are really sure no water will spread under the AG layer that is already glued. If this happens, when its dried it can permanently change appearance/colour.
Be very careful not to apply water too long as the layer underneath is the polarisation filter.
Water can soak through the AG layer and the Polarisation layer.
Again this can result in a discoloured patch.
If really really desperate, maybe use a felt tip pen (not permanent marker) to colour the exposed area to a similar shade as the AG filter. Cleaning this off wont be straightforward so go easy, wait for it to dry before deciding if you need to apply more.
This should stop it catching your eye.
i tried taking a picture of it..but the camera really isnt picking it up....where the scratch is, its on the outermost shell(?)/part of the screen. All the rest of it is a shade of dark gray/possibly black, and where the sharpener hit, it basically took the black right off, and now its white.
