Is it possible to get a panel replaced?
Uberbob102000
My LP3065 had an encounter with my cat and the panel is cracked. Does anyone know if it is possible to get just the panel replaced?
Damn, that must be a big cat. My LP3065 is pretty heavy.
As already stated, it's probably not cost effective to replace the panel itself.
Yea, he's a pretty fat cat. Weighs a good 10kg and he was running towards it.
Damnit, well this sucks.
It is cheaper to buy a new monitor than getting a replacement panel
Correct.
Personally, I would also take the opportunity to replace the cat!
