Is it my mobo??
MrT
I turned my computer on.... and it fires up... then dies 2 seconds later. Argh!!!
I had a Gigabyte 7VAXP 400 mobo with a xp2100+ CPU in it and my bro seems to think I got some gay virus that corrupted my bios... but it had dual bios...
Anyways any ideas what the problem is? Or do i need to go buy a new mobo (this one is out of warenty :( )
I'd say you should probably bring your computer to your local computer store and have them take a look at it. They probably will have an idea of what is wrong.
...Dan
:rolleyes: @ Dan17's post.
Well, the first thing I'd do is clear CMOS. IIRC, you'll have to pull the battery as good ol Gigabyte didn't have the pins for the clear CMOS jumper installed on that board.
Next, check your CPU heatsink and make sure that the fan is spinning for starters and that it's properly installed.
full specs of your comp? last thing you did with it that could have possibly affected anything?
You should always have flashing of BIOS disabled in the...BIOS hehe. When you need to upgrade the BIOS, temporarily turn it off for that purpose. It would help to know a little more info on exactly what happens after you boot up. Does it simply shut down? Are the power lights still on? Does it get past POST?
Maybe your power on button is broke, so if u power on it hangs in that state and turns of after 4 secs (maybe your 2 seconds are not exactly 2 seconds but 4)
im with masterh here. remove the battery, wait a little bit, put it back in.
also, consider unplugging all the power connections to the board.
That's a pretty common Gigabyte issue with the CMOS.
