Is it my DVD drive or something else?
Lone_Star_Lynch
Just bought Titan Quest with my best buy gift card, tried to install it, get this error message:
CRC error: The file G:\Program Files\THQ\(Whatever file that is trying to be installed) doesn't match the file in the setup's .cab file. The medium from which you are running the setup may be corrupted; contact your software vendor.
The same error has poppped up on a couple of other installers, like when I tried to install the software for my printer. It really doesn't matter which file it is because I can click retry and it keeps going, but when the file is finished it won't go to the next one unless I hit ignore, and then the error pops up a few more times until it says "the setup has encountered an error" or something very close to that and it just closes. I have a Lite-On something or other (can't find the exact model since Lite-On's site is soooo very slow, but it's just a simple cheap CD/DVD drive. It's not a burner or anything, and I think it cost me around 30 bucks.
EDIT: The model is actually SOHD-16P9SV
Bump. I've tried copying the files from the DVD to my hard drive and then installing. Same error. This doesn't make sense, a bunch of other installations get the same error.
I have this problem with Supreme Commander. I can install if I hit "ignore" and the game will install but I cannot run the patch. I have tried many, many things but to no avail (it works on two other machines but not mine, not even after a fresh install of WinXP). I know I am not alone on this since a few others have posted about this on Gas Powered Games' forum but I am ticked off about it.
