Is it just me? Or am I doing it wrong?
Silver5656
Well, i currently have 4 1.5tb wd greens in an external enclosure connected via esata (to my motherboard, not the pcie card included) using the sans digital tr4m-b. And it seems that every few days, something goes wrong. I have currently set up the drives separately (JBOD) although at first they were set up in as raid 5.
The first time I installed the drives, I had issues because I have to turn on the external before turning on the computer, and turn off the external after the computer has fully shut down, or else the drives will have issues (and by issues I mean the raid will fail and have to reinitialize).
So no round 2. No more raid (I dont really need it). Now it seems that the drives will randomly become write protected. For example, drives 1 and 3 will be write protected and thus I cannot write files onto the drives or delete files. And if I restart the computer, the next time drives 2 and 4 will be write protected but 1 and 3 will be fine, or sometimes just drive 3 will be write protected. Ok, so I finally changed all the admin/user settings so full access (which was a pita because they were write protected). And now I can access the drives.
Round 3. Now some of the drives show that there is info on there (about 300 gigs out of 1.5tb used), but when I click on the drive, no data is on there. Ok. Check for errors, and the info is back.
Round 4. drive 2 decides it doesnt want to play nice and just no longer shows up in windows. it does show up when i boot into safe mode. easy solution? re-format.
Why is this damn external enclosure giving me so much trouble? Am I being stupid and forgot something super basic? This is driving me nuts. All 4 drives have the exact same data on it now. why? because most likely tomorrow will have another issue and i'll have to back up data again. Whats the point in having 6tb in my external if its just really 4 copies of 1.5tb.............. Please help
ok, round 5, now drives 1 and 2 will not allow me to delete any files or write any files, they are write protected (even though I've removed the write protection several times)
oh and fyi, i went under security and all users have full access, so that wont work. why do the drives always switch back to write protected?
Well what kind of external casing? If it supports RAID, but connects through eSATA, it can be one of two things:
- a port multiplier, your fakeRAID drivers actually do the RAID5
- an emulator, that emulates a disk and does hardware/embedded RAID internally; no driver RAID
Both solutions are ugly, and prone to errors. Do you have a proper backup?
Also, can you explain what you mean with write protected? If you would take out one drive and put it in a different system, would it behave strange in any way?
Check to see if there are different drivers available. Even though it's on the motherboard there's a good chance that e-Sata is a seperate controller than native ich. Those type of add-ons don't always work well.
