semisonic9
- May 2, 2005
Hey guys. Built a rig about 4 months ago that I'm loving. Filling up the hard drive with all kinds of good stuff.
Looking into the future a bit, I intend to buy a bigger screen TV, a console, and probably something to play movies and handle the sound for both. The problem is that most of this would be out in the living room, so converting my current desktop to the task isn't really possible. It resides in the bedroom.
What am I looking at, at the minimum, to have a decent HTPC that plays dvds, stores movies/tv shows on the hard drive, etc. I'm assuming I can set one up as a DVR recorder, to "tape" tv shows?
I'm a little put off by the prospect of still having to buy a receiver/amplifier regardless. It's kind of lame they don't sell solid quality audio components for PCs already.
So I'm really juggling the cost/benefit ratio of buying a DVD player (possibly Blu Ray) and DVR versus building a HTPC unit. Either way, I'll need speakers and an amplifier/receiver. As far as the casing itself, it seems like careful selection of the parts list can keep noise down. I don't see the point in going fanless. I do want a nice looking case, but I figured I'd go with something like a Lian Li A05 or one of the Lancool cases.
If you were starting from scratch, would you go HTPC or not? And why?
