THE DOME said:Will one 5.25" lucite bay res. be enough for the cpu block, two videocard blocks, chipset block and two 120MM radiators?
Slammin said:I really like how quick I can bleed my system with a res. I've never tried it w/o a res though, but for, being able to bleed my system in two minutes make the res more than worthwhile.
There is also the added benifit that a res will increse the period it takes for your water to reach max temp. Not a big deal really because your water will eventually reach max temp if you run full load long enough, but the res does in fact increase the time it takes to get there. This should not be your sole reason for using a res.
Quick bleed. I have the spare space. I don't want to spend 3 days bleeding the system.
I like res.
