About and hour ago, my computer was running just fine, albeit a little loud. Being that temperatures are dropping and my average case temps have been about 20C (its usually about 60F in my house, just the way I like) I decided to take a couple of the fans out. I had 4 front intake, and 2 rear exhaust. I wanted to take it down to 2 intake and 2 exhaust to cut down on the noise.
So I take the side panel off, and the front panel, then take out the fans. I straightened up some wiring and put it all back together again. I plugged everything into the back and pressed the power button, nothing. All I got was NIC lights. The onboard flashed (I dont use onboard) and the PCI NIC card lights stayed on. So I take it apart and see if theres anything wrong, check the power connectors etc, nothing.
I take it apart again and remove every non-essential device. All that was there was RAM, CPU, motherboard, HSF, and power supply. Still didn't get anything, not so much as a beep.
I dont know whats causing the problem. It was working fine, all I did was take out two fans. What could be causing this? Is the motherboard dead, or is it the processor?
Specs:
A64 2800+ Newcastle
Epox 8KDA3I
2x512MB Corsair Value Select
Ati 9600XT
Antec Smarter Power 1.3 350W
80GB Seagate, 40GB Maxtor
DVD+RW DL drive
CD-RW drive
Until I figure this out, I'm stuck on my P3 800, with 192MB of RAM and a failing HDD.
Specs:
A64 2800+ Newcastle
Epox 8KDA3I
Ati 9600XT
DVD+RW DL drive
CD-RW drive
