Is it a bad hard drive, memory, CPU or what?
tmarshall
I sold a PC to some people. I had to ship it because they are too far away.
It had Windows 2000 with all the updates.
I ran Prime95 on it for 16 hours. No problems.
Ran memtest.
No problems.
As soon as they get it, they claim...Machine powers up, shows windows 2000 screen, then screen goes black with snow.
Never really saw that before.
What do I do? What faulty part would you suggest?
something got moved out of place while being shipped (most likely)
tough call.. more info needed (and more testing)
have them restart it 5 times, and time each reboot.
basically, you want to know if it does that at the same time everytime? or not
if no, and it does it sooner, the more times they restart, then most likely cpu heat problem
if yes, might be ram
HD- unlikely, but possible if yes. have them run scandisk (if possible)
i presume, goes blck with snow, you mean like a tv?
(ask them to describe it a bit better and talk to them as they boot up)
ask them to boot in safe mode.
for the future, get yourself a copy of knopix, and don't leave home without it
its a OS on a cd, ready to be booted, so yo can find half the problems in a second.
If they're getting "snow," my guess is the video card got jolted during transport. I'd have them reseat it.
might be.. but
1) a screw secures the video card
2) they would see only snow from the very beggining..
a video card behaves like a drive.
its either connected, or its not.
If the videocard was not seated correctly, you most likely wouldn't boot at all. Memory and CPU, and HD errors would give you a descriptive blue screen. Therefore, it's none of the above.
It might be you had it set to a resolution/refresh rate that your monitor supported fine, but that their monitor doesn't support. That explains why it displays everything perfectly until after the win2kpro screen.
Hold f8 on startup and see if it gets to safemode. If it does, uninstall the video adapter, then boot up normally.
The video card can be "partially" in the AGP slot which gives crazy displays (it's happened to me); which is why you should reseat the card after shipping.
Well then...ignore the reseating part...heh.
