Salty Wagyu
- Jan 21, 2011
Hello chaps, building a new HTPC has been on the cards for a while. I have considered building an Atom ION system (or buying the Revo 3610) but I have decided I do not want to rely solely on graphics acceleration for HD playback.
I have looked into getting a beefier CPU so I can use that instead for HD playback, and the i3 seems to fit the bill, being energy efficient too.
The reasons I don't want to depend on graphics acceleration has come from a recent experience of trying out DXVA in Media Player Classic on my PC and seeing how it can't run alongside with DirectVobSub, as I heavily use this for subtitles (I have some hearing loss).
I've found MPC's internal subtitle renderer to be crap when I tried out DXVA and I didn't like it, even adjusting the sync of subtitles didn't seem to do a thing. I need to be able to adjust the sync of subtitles as they can be out of sync by 1-2seconds sometimes.
Other things I've had to tick off the list as not suitable for me:
a) I've found out (from others) that XBMC supports the major subtitles, but doesn't have anything to adjust subtitle sync on-the-fly.
b) PS3MediaServer (yes I have a PS3), but no support for .idx/.sub nor any on-the-fly syncing options
c) Any form of ready made media players such as WD Live, Popcorn, etc. are quite vague on what they support, plus it's likely these devices would have other small issues of their own that I can't be bothered with.
I haven't drawn up a specs list yet, but I am asking if an i3 based HTPC will suit me for CPU-only rendered HD playback. I intend to install Windows 7 and the CCCP codec (which includes MPC) package to it. I will also be using KMPlayer and VLC which uses their own in-built codecs should I have trouble with certain files.
I've often wondered why some people are getting their HD content accelerated from the onboard graphics on the i3 when the CPU is capable of doing it alone? Is it something that the i3 or intel graphics driver forces natively for all media applications regardless if they do hardware acceleration or not?
Thanks for any advice - remember that it is specific to the situation I am in, if it wasn't for my hearing loss I would have probably bought/built an Atom/ION system!
