Hyperthreading works well with Linux too. Just use a SMP kernel.wallijonn said:Only if you have WXP Pro. If you're running anything else it won't 'run'.
ShuttleLuv said:It doesn't really help against a A64 though.
Not many games have hyperthreading.
You might as well use it in conjunction with an i875 mobo so that you also get PAT.
Try getting an A64 to fold and DiVX encode at the same time.
dave_graham said:it's a good technology that should provide tangible benefits for your daily life.
cheers,
dave
nigel.pinder said:I thought it was hype, until I tried one. I have compared A64 and a P4 with HT. When playing a game or doing 1 thing the A64 is faster, BUT if you want to do more than 1 thing at once, the P4 with HT feels much more responsive and doesnt `slow down`.
From actually using the pc rather than running benchmarks, the P4 seems best for me.
Josh_B said:As you know, Intel and AMD are both planning true multicore CPUs, due to arrive sometime in 2005.
0ldman said:I just have this feeling that they'll keep the dual core chips priced relative to the single core chips vs SMP now.
Single core ~$300
Xeon dual core ~$600
That is probably the single reason most of us tech heads don't have an SMP system *right now*.
I don't need it bad enough to double the cost of my rig. I really hope they don't go that route with it tho.
rally9x said:HT is implemented pretty hard core in photoshop. It makes a huge difference on some jobs.
yes.fore1337 said:Can you Ocerclock in HT mode?
...and now I have it back.pxc said:I miss it for certain tasks.
They don't have symmetric multi threading, they have symmetric multi processing, what SMT is pretending to be.Lord of Shadows said:The new dual core intel cpus dont have ht =(
0ldman said:They don't have symmetric multi threading, they have symmetric multi processing, what SMT is pretending to be.
Where's the problem?
