Because no gtx 260 have HDMI at newegg and considering they are a newer card you would think they would have built in HDMI, or at least one of them would.
also are there any single slot coolers that can be put on a 260?
yeah I know they have adapters but considering HDMI is almost a standard in TV's and Monitors I would have thought it would also be a standard with Video cards and considering it's not I thought maybe it was going away.
They seems to be common for other gpu's like the 4870 and 9 series but not the gtx's.
I am fine with DVI as well but my monitor and tv don't have a dvi port only HDMI and D sub.
I cant seem to get sound to my TV with this setup....how did you do it..My evga 260 came with an hdmi adapter, and I'm actually using it right now to run a 32" lcd tv as well as my regular monitor - sound and all.
I used to use the S/PDIF pinout on my Auzentech Xplosion on a HDMI equipped 7600GT. Now I use the pinout on my motherboard (EP45-UD3LR) connected to the 260 using the supplied cable.
What motherboard and soundcard do you have - maybe it's just not connected to the right pins. I'm assuming you've installed the audio drivers for the onboard sound, but check to make sure that is all enabled. All I had to do then was open the audio preferences and select which I want to be as the default - super easy to do in W7 and Vista. Additionally, there is another option on my TV side and you can set if the audio comes with the HDMI or through a separate imput. the TV works with another HDMI source like a PS3 or whatever, then that should be fine.
Oh, and I've heard that the vid card can be picky about which DVI output you connect the adapter to.
its an MSI X-48 board, and the PCI-e X-fi sound card that comes with it..i also tried it with a sound blaster....on Vista 64...
Thank you..Ill try that and see what happens...Try the pinout directly on the motherboard itself. It's labeled JSP1 on this diagram and the lower of the two pins should be the ground.
FYI, DVI and HDMI are the same video signal. They just have different pin layouts, and HDMI adds audio. See http://en.wikipedia.org/wiki/HDMI and http://pinouts.ru/VideoCables/hdmi_dvi_cable_pinout.shtml for more info. This means that HDMI-DVI adapters are actually less complicated than DVI-VGA adapters.
They might even be able to get away with not having to go through all that for the adapters, as they're not really devices, just pinout-changers.
is display port hdcp? i wish that would go away too
No HDMI cannot fail anytime soon, as it is the worst connector ever invented, thus it will not fail. Same with Display Port... FAIL.
Connectors with pins and screws FTW!
There is no screws and clips as that is just to complicated for the general public. True story.
