Is hard drive temperature very important?
DellAxim
The main component I always worry about in my computer is the HD, because I'm terrible at making backups and they're expensive to replace. My hard drive seems to idle at about 90*F. Would it increase the expected lifetime and/or reliability of my hard drive to cool it another 10-20 degrees?
Around 30C is well with in the acceptable temp range for an HDD, this isn't 1980 where you were required to put the computer into sleep than to turn off b/c HDD's back then couldn't tolerate the temp fluctuations. HDD's are tested in varied environments and conditions, and it wouldn't matter either if you cooled it even more.
In other words, you're fine. Don't worry about it.
In most systems you would be hard pressed to stress your HD temps in normal operation.
90f is nothing to any modern HD.
The 7200.11 in my system can take 60 celcius.
The only situation I can see you running into a HD temp problem is that you are trying to shoehorn a big drive into a HTPC case.
Don
I know 90* is within the acceptable limits....but would it last longer/be more reliable if it were cooler? It seems every time I've ever had a major computer failure in the last 10 years is because of the hard drive.
Kinda like a car. They'd run fine and last a while at 100mph all the time...but they'd last even longer if you drove like a grandma instead.
DA I think you're totally fine running at 90F / 32 C. In fact, the only times my HDs run cooler than that are at initial boot-up, or when the computer's next to an open window on a winter night :cool:
If I rip a DVD or do other intensive HD tasks, I'll see drive temps climb to 39C (102 F), but only temporarily, for 15-45 minutes. And that's with 3 HD's stacked on top of one another .... when I had one isolated, it was easily 3-5 C cooler just because of airflow and ambient temperature improvements. This is with a single 120mm front case fan spinning at 1200 rpm (pretty low speed).
It's good you're paying attention to it, but I can't possibly imagine that temp being a cause of failure or even leading to any degradation in long-term reliability. More important is what shocks, hits, power surges/spikes, & on-off cycles it sees. keep it cool
PS the grandma stuff is usually true... but some car engines goto sh*t if they're driven slow -- sometimes equipment Needs to be used as it was intended :D
This is according to everest
They have been on for 8 hours so far today.. and have been moving TV shows accorss them..
the only fan blowing on the 3 are the rear 80mm intake. i have to to blow accross the cpu, and to the HD's
Check out the Google paper "Failure Trends in a Large Disk Drive Population". One of the main things they looked at was correlation between drive temps and failure rates. Very interesting read.
My take? 30-40C is normal and nothing to worry about. More than 45C and I would consider additional cooling. I'd worry about anything above 50C.
I'm pretty terribly so I'll be getting a second computer to do backups for me soon. Why don't you look at raid or a 2nd HD and using some automated software or something if manual backups arent your thing?
Yeah...I want to get some kind of raid setup...but I'm cheap, and lazy. ;) Really I only feel safe with my most important data when I have 2 copies of it on DVD. I've lost far too many important things in the past due to not just one but two or three consecutive failures...:mad:
30C is pretty close to room temperature, so I wouldn't worry about it.
I wouldn't use RAID, BTW. Writing backups to a second system or external HDD is far more secure, especially if you use automated backup tools.
