Happy Hopping said:sure, especially if it is a 30" LCD monitor
unearth01 said:I ahve 1 Mitsubishi 930sb and want to get another. I want to do a dual screen setup.
Is it even worth it. pros and cons
AMD T-type said:just in case you wanted to know what two 930SB's looked like
that is my roomates setup, personally i have two NEC FE990's
i really had no reason to go dual screen, i'm not a huge multi takser, but i will tell you one thing, i dont think i will ever have a single monitor ever again![]()
unearth01 said:do they interfere with each other. I knwo when I turn my 930sb on it messes with my bros monitor across the room. I know when you degause but what about when they are just on next to each other. When out computers were together he and i would always get mobing lines on the screen, What is that
Blethrow said:Heh, I'll be joining that club too in few months.
Happy Hopping said:How? You have a 3400.
And would it be a 2nd Apple or the upcoming HP L3035?
And I ask Denis the same question I ask you, would you recommend the 30" Apple? What are the good things and bad things about it in terms of performance and quality?
Happy Hopping said:but 250 cd/m2 is good enough for you?
What about the speed? Dell's 24" is kicking at 12ms, at people around this board keep saying 16 ms is not fast enough.
And when I talk about speed, I guess I need to know if you can response in terms of games until you do primarily business application.
Blethrow said:When there is a brighter one available of equal or greater size, I will buy it. But for now, as it is the only option in this size range, I still consider it distinctly worthwhile..
thats exactly what i do... best thing to do...unearth01 said:when you have the dual monitors, can I play a game on my main screen and then have my Aim, Downloads,Ventrilo, Irc open on the other one.
i suffer from withdrawal whenever i travel because i miss my second monitor so much...XeRo_Dark said:hell yah dual monitors is worth it, i cant live without them
TheExile said:NVIDIA's drivers have the option for seperate wallpapers, in the desktop management desktops menu
burningrave101 said:Is there a way to do this in extended mode using ATI drivers?
Pt3000 said:How about 1 L90D+ now.......... and 1 L90D+ later![]()
