Is DDR2 667 the same as DDR2 675
could you post links?
as far as I know, its a marketing gimmick. But heres a general rule of thumb - if your board supports a max of 667, you can use higher speed rams but they will only run at 667. So the 675 should run at 667 for you if thats your board max.
corsair xms2 memory speeds are DDR2 675, DDR2 800, DDR2 1066, DDR2 1111, & DDR2 1142.
When people talk about memory, they keep mentioning DDR2 667 but I can't find that memory so I wanted to make sure DDR2 667 = DDR2 675.
Just a little background, I plan to buy an e4300, a DS3, & 2 gigs of Corsair xms2 DDR 675 memory.
Here's a link to the DDR2 675 memory:
http://www.newegg.com/Product/Product.asp?Item=N82E16820145015
Youre set. The module is on corsairs list of supported modules.
533, 667 and 800 are the standards, all this means is that corsairs memory runs at a slightly higher clock frequency. since the DS3 supports upto 800 MHz of ram, I dont think you'll have an issue.
Only thing im not sure about is whether this memory can boot on 1.8v, which is generally the standard voltage to DDR2 ram. Ill leave that for someone else to clarify since im not sure.
There are both 667 & 675; basically the same. in this market, I think the Corsair will be the cheapest and will perform on par with anything else. Crucial is 667, rated pc2-5300
Also you can save a few bucks and buy that same kit for $159 shipped over at ZipZoomFly or just buy 2 1gb stick @ $75ea*2=$150 for 2 GB. just a thought
