Is Corsair HX620 Enough?
firebug88
I have three PSUs as follows:
Tagan 800w Modular
Corsair 750w
Corsair 620w Modular
I want to use the Corsair 620w for my main computer but wasent quite sure if it was powerful enough for my system. My specs in sig. Can someone tell me which one i should go with? I currently have the 750w installed but it crapped out and is on its way back for a RMA.
I have an HX620 with the following:
E8400 @ 3.6
2x2GB RAM
several hard drives
BD-ROM
GTX 260
According to my UPS, which is also powering my 25.5" monitor, the idle power draw is about 150W. Peaks around 350 during intense games, etc. You can use any of the three.
Thanks, I was thinking that it should be enough but i just wanted to make sure. I have to RMA my mobo and my psu so i didnt want to make a bad choice.
The HX620 is the PSU I'd pick out of those three. It's definitely enough for your system. Consider that I run a system with comparable power consumption to yours off an HX520.
