Is BTX Dead?
Cabn12
What ever happened to the BTX form factor. Has it been officially killed off?
What happened to it is the reduced power dissipation of Core 2 duo, the BTX was Intel's band-aid answer to the Prescott P4 furnaces that would throttle themselves at even medium loads due to heat with conventional cooling. But it is not officially dead, it is a dead end, the Thermal and Mechanical Guidelines document still has a BTX section for the cpus and chipsets. However, if you put the BTX spec in a box and buried it six feet deep it would be difficult to tell the difference from it's current status.
No. Many OEM systems are still BTX, including models by 3 of the top 4 manufacturers (HP, Dell and Acer... Lenovo went back to ATX last year). I've even seen AMD BTX systems.
It has pretty much disappeared from the DIY market, with very few models of boards still being made for non-OEM system builders. That's a shame really because BTX is better than ATX. I really liked the layouts of the regular size and SFF BTX systems I had.
The "need" for BTX is still the same as before. It's an improvement over the ATX form factor (better CPU cooling path way, slots face upwards, improved drive cooling). Last I saw, the "hot" 115W Prescotts have been eclipsed by "cool" running 125W dual (AMD) and quad core chips (Intel). :p
It's pretty much dead. The OEM's are using it more as a cheap proprietary alternative.
It's generally the opposite of that. The low end (cheap) is almost always micro ATX based on OEM systems.
Oh, please. That was FUD 3 years ago and proven false even back then. :rolleyes:
in short: dead
in long: dead
in very long: dont know, but i wouldnt mind if it becomes the standard in the future, say 5 or so years. most parts of BTX just simply makes sense when compared to ATX. i mean, who wouldnt want upward-facing cards? then again, theres reverse ATX cases too.
Link Please, my personal experience is otherwise.
OP, you ask the question like it was born at some point. As I see it, it's still in the womb. It seems the biggest benefit for BTX is smaller form factor PCs. The DIY market seems to be doing just fine with ATX, why mess with it. BTX would cause manufactures to divide their offerings making less products available. Now you have competing formats with less choice. If it does come to fruition in the DIY segment, it would take a while.
Right now the issue is that motherboard makers don't want to invest in btx untill there is a good selection of cases that people can use it with. The case makers don't want to push BTX untill the motherboard makers are on board.
BTX right now is used by some of the big vendors like dell and gateway. One thing that companies like dell like is they can drop the noise level with BTX and its better cooling design. A nice big speed controller fan in the front of the machine cooling the cpu does a real nice job. I would love to see btx take off a litte more in the diy market but untill you have a good selection of cases supporting it and atx(so users can upgrade to btx) I don't see it happening.
