Don't worry, the bots are a lot better than in Battlefield: Vietnam. They can fly choppers the right way round, drive fine, occasionally fall off a bridge (oh, no wait, that one was meAelfgeft said:I guess what I mainly want to know is are they a hell of a lot better than the BF: Vietnam bots. I bought that game and was just absolutely disgusted. Seemed like the AI technology went backwards. Ah, great...they're driving tanks off of bridges! They're flying helicopters upside down! They're flying into hills! They're molesting each other with napalm!
Okay, yeah, I made that one up, but it wouldn't freakin surprise me![]()
Scoobydo said:It would be good if they werent 16 player maps.
If you could select the 64 player maps (bigger where you have access to planes, heli's, etc) then it would be fun.
You can basically see across the 16 player maps and are basically infantry only. A few maps will give you the heli's. One map a plane. But thats about it.
Aelfgeft said:You can't select all the maps? Then how many bots can you have in the game?
Jeriko_Cherry said:There are a couple mods that have altered the bots to work on larger maps and with more stuff. Here is one: http://totalbf2.filecloud.com/files/file.php?user_file_id=47158
But still, I love BF2 and have BFV, BF1942 w/ expansions and I can honestly say I wouldn't buy BF2 to play singleplayer. While it's fun to jump into a lan game and frag some bots it mostly comes down to a meat grinder with you pushing the button. The bots tend to use the same tactics in the same areas over and over again. There are three levels of skill for AI bots in BF2, on the second level (veteran) they tend to be too easy and on expert you'll get shot from across the map before you even know an enemy is in line of sight. Needs somekind of better middle ground on the AI skill because Veteran doesn't cover it.
