EDIT 7/25/2006: My theory, which has little to no basis in the real world, was that the main ATX connector might be an issue. For the seasonics and fortrons the power connector is split, but for the antec, and now a silverstone 750w, the power connector has all 24 pins in one unit. I know I don't have a very good distribution of samples having only a limited number of psu's, but it does appear that split connector psu's give weird issues in the bios readings (sometimes). To summarize, with one piece connectors (24 pins) the motherboard readings are as they should be. With two piece connectors the 5V rail often reads at 4.34V and the 12V rail is sometimes (rare) at 11V. I plan to get another silverstone and see if it fixes the other computer that has bogus readings. Any thoughts you guys? Is this just a question of the extra 4 pins not seating correctly? I can't seem to get it to seat any more firmly and it is flush so I don't really know why having a split connect would cause any problems. That being said my initial instabilities haven't cropped up, so the replacement seasonics probably would have worked just fine. Meh.
UPDATE 3/24/2006: 2 good and 7 bad
UPDATE 3/11/2006: So I was wrong about the good replacement, it had the same problem the others did. Now I have 2 good ones and 5 bad.
UPDATE 3/10/2006: I have received 3 replacements, only one of which was good. The tally is 3 out of 7 have been ok. I also noticed that the 12V line drops in addition to the 5V line. If I believe my bios the 5V line flips between 4.3V and 5V every 10s or so with most of the time being spend at 4.3V. For the 12V line it flipped between 11.1 and 12V every 5s or so, with equal time for each.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I bought 4 of these power supplies to replace the antec truepower 2.0 550W ones I had before b/c of long term problems reported on anandtech. However, I have had stability problems with two of them (2 seem fine), both of which have low +5V lines, 4.34V. Did I just get 2 bad power supplies or should I move over to pc power and cooling 850W ones?
