is any problem on my 4870x2 ?
billtaco
my PC :
CPU QX9550 3.4G
RAM DDR2 1066 2g*4 (only up to 3.5 G on XP)
motherboard Gigabyte GA-EP35-DS3
videocard : powercolor 4870x2 2G DDR 5
but my current system was XP SP3
and run Crysis v 1.21 with
24 inch BenQ V2400W : 1920*1200 all only high and only 2AA no SynV
my god : my FPS only around 20~25
If set to very high --> the FPS down to <15 sometimes only 5~10
what is the problem, driver ? or system ? vista will be better ?
my current driver is from the " original CD " in the box of my product box
Is the 8.8 version driver on the official site for 4800 series fitting my 4870x2?
Please !!!!
The problem is Crysis. NO system (Absolutely NOTHING ) can run that game well on very high. Your system is fine.
Will you please go to Overdrive tab in Catalyst Control Center and report back about your GPU Activity? Installing SP3 to XP causes my 4870X2 to lock at 135% GPU activity, and my CPU to lock at 50% activity (100% on one core). With SP3 I get very very bad performance in all games. Removing SP3 puts GPU activity back to normal levels and performance is as properly fast as you would hope for a 4870X2.
I have to pretty much agree here. For some reason Crysis runs especially bad on ATI cards. The only way I've seen Crysis playable at Very High settings is a GTX280 Tri-SLI but the cost/performance ratio for that is so pathetic it isn't worth it for just one game.
Multi-GPU support in Crysis is pretty poor, moreso with CrossFire than SLI. I blame the game, it is the exception to every rule.
