Pixel Eater
- Oct 25, 2006
If s/pdif is simply a digital signal for some other source to handle, are they all identical sounding? Or would a high end card's have way more quality some how?
The S/PDIF standard is frequently "broken" in many implementations. As an example, some vendors support extended word lengths and sample rates that aren't, and haven't ever been, defined in the S/PDIF standard.s/pdif is a protocol, so for it to actually BE s/pdif, they should all be equal. I'm betting this is not true in every case, but unless it was broken, I've never found any differences.
Sorry, but this is blatantly misleading.So to answer the question, yes, there is a BIG difference between SPDIF outputs on various sound cards.
I just upgraded from an nvidia Soundstorm (found on the NFII motherboards, amd athlon xp era) to an onboard realtek (ALC1200) which is on the newer ASUS boards.
Using the same SPDIF coax connection to my receiver, there is a HUGE sound difference. The realtek is flat, muddy, and has limited tuning and output options. The soundstorm was powerful, could bring out tons of bass from my tower speakers (no sub) and had plenty of software tuning and output options.
Okay, so after that, I guess rather analog or digital sounds better depends on how good your receiver and or pre-amp is?
