RancidWAnnaRIot
EspantaPajaros
- Feb 19, 2004
Do any of you guys know if ABS plastic fumes and filings are bad for you?
like cause cancer bad?
Viper16 said:any fumes from anything are bad...I would wear a mask if I were you in a well ventilated environment...
nobody_here said:i wouldnt worry much
i used to work on a farm, was handling Temec(systemic insecticide, extremely dangerous) and Treflan(today's equivalent to Agent Orange), among other chemicals barechested with nothing on but a pair of shorts, no resperator or anything, and have had no signs (after 15 years) of any damage
dcds1 said:The fumes from any burning plastic is bad for you. When plastic burns it creates Hydrogen Chloride which is very poisonous. So when you take your dremel tool to cut out plastic you are heating the plastic and creating the hydrogen chloride. You should always wear a mask with charcoal filters and cut the plastic outside.
Damn. I hate seeing posts like that. Not only because you have potentially exposed yourself to dangerous chemicals. But also because such posts can give people a false sense of security.nobody_here said:i wouldnt worry much
^^^ - Well said!!dcds1 said:The fumes from any burning plastic is bad for you. When plastic burns it creates Hydrogen Chloride which is very poisonous. So when you take your dremel tool to cut out plastic you are heating the plastic and creating the hydrogen chloride. You should always wear a mask with charcoal filters and cut the plastic outside.
Zallek said:I totally agree with the respirator comments... I work in a welding shop (not quite the same, but the idea is here) and sometimes when I change my filters out you couldnt even tell they were white to begin with.. Even if you dont get sick from it, things stuck to your lungs can cause serious problems.
Susquehannock said:Get a respirator. Never ever take your health for granted. Without it you have NOTHING.
Make no mistake, many chemicals can lay dormant in your fat cells, liver, brain, (among countless other places) and resurface to cause all sorts of ailments years or even decades later.
Remember one thing ... if you can smell the chemical you ARE exposing yourself.
