Is a sound card needed using digital out?
munkle
I was under the assumption that using the digital out (rca/fiber optic) bypasses any sound processing (is this true?). So is a sound card even needed when using the digital out?
This is how I understand it. The receiver produces the end result when it receives the digital signal. So, onboard sound is the exact same as a sound card when we are talking about digital.
Yeah that's what I thought but with the realtek application I can apply sound effects to the digital output which would mean that it is processing the sound. This why I'm a little confused. I'm using a Yamaha receiver to hook my speakers up to.
Generic soundcards do two things these days:
1. provide a digital output and/or DAC to produce sound
2. provide a digital input and/or ADC to capture sound
That's it. Most processing is done via your main CPU, unless you have a special card with more features.
If all you are using is digital output, the sound card is not necessary - the sound can be decoded and processed by your CPU. What is necessary is the standardized physical interface (SPIDIF or HDMI) to output your digital data.
I see no reason why receivers couldn't come with USB connections that identify as a standard USB audio device. Then you could use a ubiquitous interface like USB, and pass on the whole on-board audio thing. You could also output multi-channel sound without real-time encoding it into DDLive.
