I'm currently running a BIP2 on a 1/2" loop with a DDC+ (plexi top mod), TDX 64+ on a Opty 165 (OC'ed), Maze 4 plus MC14's on a X1800 XT, and a 3.25 bay res. The loop has been solid, and stable for almost 2 years, 24/7. (PC Ice, with Yate DSL12SL's)
I'm doing a system refresh, and moving to a Q6600 (G0 stepping), Abit IP35-Pro, and BFG 8800 GT. I'm swapping the TDX for a Apogee GT. I'm currently waffling on keeping the Maze 4 for the GPU block (with MC14's on the Mem/Mosfets), or going full vid card block (EK).
My concern is how much heat the Q6600 and 8800 GT will dump into the loop (and yes, I plan to overclock as much as possible on both. My Corsair HX620 should be good to go on the load). My system is pump/BIP2/CPU/GPU/Res/pump.
I'm thinking about adding a BI GTS 120 in-between the CPU and GPU to dump CPU heat as much as possible before hitting the GPU.
Thoughts??
Would that be adding too much uneccessay restriction in the loop? Knowing that a loop will for the most part thermally balance across the entire system, is the BI GTS 120 overkill?
That, and is there a thermal advantage to a full GPU card block, as opposed to keeping the Maze 4 (which does fit a 8800 GT) with MC14's on the ram/mosfets? Knowing that the bottleneck for the vid card is ram related, I'm assuming the full card block will allow for better temps.
Thoughts??
