lessthanuthought
- Sep 4, 2013
My cpu was at 90c while running prime95. Is that too hot?
Thanks
Thanks
What CPU do you have? Should be fine if it's a Sandy or newer. Max is 100-105 before throttling down. Personally, 90c while hot, you'll likely never run that hot using the cpu under normal stress conditions.
With that said, I don't like to run past 80c. I don't like playing too close to the edge![]()
3770k.
yeah 90 seemed high. I am waiting on my heaksink for the CPU still.
Then all fine bud, the stock cooler its a pile of crap..
3770k.
That is too hot for Prime95 for that CPU IMHO. Prime95 is also outdated and not a good indicator of stability for the newer CPUs with AVX and AVX2 instruction sets. You need to use the latest version of IBT. On my 2500k at my clocks/voltage/cooling ill get low-mid 70's in P95, and near 90's with IBT with AVX support. For reference, BF3 will get it to mid-high 60's.
I realize your running stock clocks/volts/cooler, so if your 100% certain your HSF is mounted properly you may want to improve fresh airflow to the cooler, as well as improving hot air exhaust.
Yup, then I'd say that's totally normal. Stock coolers are so trashy they should just discount you whatever it cost AMD/Intel so you can front for a cheapo $30 cooler that will put it to absolute shame in comparisons.
On my Q9550 @ stock 2.83Ghz the stock cooler was doing 90-95 under full loads, not including Prime95 or IBT. It was pretty bad. Once you drop that aftermarket cooler with a 1Ghz OC it never reached higher than 70C under unrealistic Prime95/IBT conditions with one of the cores reaching a max of 75C (normal). Other than that full encoding of H.264 video, which is probably the best authentic way to test real world scenarios, or gaming, it would never come close to 70-75C.
I'll get IBT, and use that from now on thanks. I'm 99% sure the HSF is on correctly, and I have 5 noctua fans running in an Fractal R4, it seems that airflow should be good, no?
Thanks everyone for the quick responses so far.
The intel HSF are notoriously shitty for being difficult to mount. Easiest way to tell is to look at the back side of the motherboard and see that all the little black pegs have popped through all the way. Your motherboard will be bowed slightly if its installed correctly, they suck that much.
5 noctua fans...depends...are they oriented to create flow or are they just randomly blowing in and/or out? A typical flow is front to back, bottom to top.
I was just playing Crysis 3 and it only was in the mid 60s. I have some videos I have to transcode later, I'll check out the temp while doing them as well. Right now I'm idling at 39c. MB is at 31c, GPU is at 44c.
Wrong on so many levels. Prime95 has supported AVX shortly after Sandy Bridge was released. And the author is currently implementing more instruction sets for Haswell CPUs.
And the creator of IBT hasn't updated his program for the latest Linpack. If you want to take advantage of AVX2, you need to use LinX v0.6.5.
Oh boy, nice try but im not wrong. Point to where i said Prime95 didnt support AVX.
IBT with AVX tortures a CPU way more than P95, i literally downloaded the new version of P95 and tested right before i made the initial post, then ran IBTv2 with AVX. Stop trying to call people out for no reason and with no backing. The only thing i didnt know was that IBT didnt support AVX 2.0 yet, because...brace yourself...i have a SB and havent needed an update to IBT. My fucking bad.
Right here:
You said that it is outdated, meaning it doesn't support CPUs with AVX or AVX2. Obviously that isn't true.
Try running Prime95 with small FFTs for about an hour or two. It should heat up just as much as any Linpack program.
And it doesn't matter if you own an older processor or not. You can still read up on this "new" stuff.
The fans are two intakes in the front, one intake on the side, one exhaust on top, one exhaust in the back.
It is outdated, whether youd like to accept that or not is up to you. Its old. There are better stress testers like linpack now. That doesnt mean it doesnt support newer processors with AVX. If you want to misconstrue what i said, then by all means...be wrong.
You are wrong, plain and simple. You are basing your facts on the fact that linpack is better, when it really isn't. You can run an "old" version of Linpack/IBT and be stable, yet crash and burn with the latest binaries. The same thing goes for running an "old" version of Pime95. The author was quick to add to in AVX support, and is working on AVX2..Considering he does this on his own and isn't a huge company like Intel, then I would say that is pretty good.
Your reasoning behind Prime being inferior, is just that inferior. You are using a quad core without HT, which is MUCH easier to get 100% stable vs a cpu with HT..Those of us with HT and want TRUE stability testing with IBT/Linpack have to launch the program, go into Task Manager, lock the affinity to the proper cores, then test..This gets old quick. With Prime95, we launch the program, and let it run. Simple as that.
I have used BOTH programs, and have screenshots that show the same temperatures (+/- 2C) for short runs (10 to 30 mins). Once you start doing long term testing (100 runs of IBT on "Extreme", 24hr+ Prime95), Prime consistently produced higher temperatures.
Disclosure: I also have a "high end" water setup![]()
You are wrong, plain and simple. I can spout most of the same shit back to you in an opposing fashion...nothing you said makes you right, nor me wrong.
Ive used both as well. They dont produce a difference of 2 degrees. Fluctuations between cores are frequently more than 5 degrees. But you would have had to play with multiple CPUs to know that. Im talking 15 degree differences between the 2 test methodologies, and can also provide screen shots. Im also talking about my CPU being Prime stable for 12 hours at 1.42v. Then firing up IBT and having it crash with in seconds. Youre just one more random nobody on the internet that is in the mood to disagree with me. Good bye.
so.. do it, prove those 15 C difference between Prime95 27.9 Small FFT and IBT... Do it.. you can even use the new intel linpack for haswell that work pretty well with sandy and ivy...
It is outdated, whether youd like to accept that or not is up to you. Its old. There are better stress testers like linpack now. That doesnt mean it doesnt support newer processors with AVX. If you want to misconstrue what i said, then by all means...be wrong. I can make my system P95 stable for hours, and watch it crash and burn as soon as IBT is fired up. Calling P95 a good indicator of stability these days is an exercise in futility.
