~¥~ßLÅÇK~ÇîrǵT~¥~
- Jan 27, 2004
Via Aqua 2600 pump.
1/2 ID tubing
Is this bad?
1/2 ID tubing
Is this bad?
xyoufailmex said:I would think, in a small application such as CPU cooling, that GPH would have a point to where it started giving you negative effects, as in the water is rushing through too fast to have time for the heat to be transfered to the water from the block.
flak said:nope. doesn't work that way. you want the maximum temperature difference between the copper and the water. water just sitting in the block = bad. the only thing he'll really need to worry about is making sure his reservoir (assuming he's using one) is big enough to avoid having so much cavitation that air gets into the lines. other than that it's just a matter of making sure his hose clamps are tight enough. oh, and having enough room for the pump is a plus, too.
zer0signal667 said:You're right about the flowrate, water doesn't need any residence time in order to soak up heat. However, cavitation is nothing to do with the water in the reservoir. It occurs when local water pressure is reduced enough to induce boiling, which creates pockets of vapor that collapse almost instantaneously. Air getting in the water can be due to water sloshing around in the reservoir, which I think is what you were getting at.
killernoodle said:Cavitation occurs in some loops where the pump is restricted on the inlet. People put reseviors before the inlet of the pump because this is naturally the least restrictive part of the loop and also serves to even out pressures when there is a little bit of air in it and helps prime the pump. I had 2 via aquas die from cavitation before I discovered this.
Maximus825 said:The problem with a pump like that is, it'll be dumping all kinds of heat into your loop. So much so, that it counters the performance benifit from high flow...
This works with people but not anything else. Wind Chill does not effect metal. If it's 40F and the wind is blowing 10 mph, the wind chill will make it feel like it's 34F. It isn't 34F it just feels 34F. So no matter how fast the water is moving it will still be the same temperature, all other things being equal.Jason711 said:all i know is the faster the wind blows the colder i get... water would be even worse.![]()
WheresWaldo said:This works with people but not anything else. Wind Chill does not effect metal. If it's 40F and the wind is blowing 10 mph, the wind chill will make it feel like it's 34F. It isn't 34F it just feels 34F. So no matter how fast the water is moving it will still be the same temperature, all other things being equal.
The formula for figuring out wind chill is:
Wind Chill(F) = 33.74 + 0.6215T - 33.75(V^0.16) + 0.4275T(V^0.16)
where T = air temperature in F and V = wind speed in mph
thewhiteguy said:Make sure your lines are secure, that will create quite a bit of pressure in the tubes before your block, if it's very restrictive.
killernoodle said:Cavitation is not only limited to large propellors and such. It is only a product of pressure really, the pressure at the front of a pump can be so low that the impellor cavitates (basically creates its own air bubbles with no air to make bubbles from) on itself. You can achieve the same effect if you take your arm and move it rapidly through water.You will notice that you will leave an air pocket following your arm, but there is no air to get in there. That is cavitation.
killernoodle said:Way to go!
http://en.wikipedia.org/wiki/Cavitation
It can happen in any manner of pumps, all that it needs is a partial or total blockage of the inlet of the impellor and the impellor to "suck air from nowhere". If your pump does this, it is cavitating. There is no other explanation for it.
I had 2 via aquas die form cavitation, they became noisy, then rattly, then they simply were untolerable.
killernoodle said:test this theory in a kitchen sink. If you bring a powerful water pump close to the surface, it will create a vortex and begin to suck in air. If you block the impellor it will usually begin to cavitate, even if you cant see it. You can usually hear it though if it is a powerful pump.
Jonsey said:The main consideration is how much heat a pump dumps into the system. At some point, (over 50 watts) the amount of heat a pump generates negates any benefit higher output brings. Where that point is depends on the rad/fan combo used. Check out this thread, the best testing I've ever seen, as well as input from the guys that actually design WCing systems for a living:
http://forums.procooling.com/vbb/showthread.php?t=10825&page=1&pp=25
mwarps said:Now the question remains, where in America can you get an Iwaki RD-30.
Jonsey said:From the link above:
+20.7C => Iwaki RD-30 @ 18.0v
+20.8C => 2 x Swiftech MCP600 @ 13.8v (series)
+20.9C => Swiftech MCP600 @ 13.8v
+21.1C => Iwaki MD-20RZ @ 60Hz
+21.1C => 2 x Swiftech MCP600 @ 12.0v (series)
+21.2C => Iwaki MD-20RZ @ 50Hz
+21.4C => Swiftech MCP600 @ 12.0v
+21.4C => 2 x Eheim 1048 (series)
+21.5C => Iwaki MD-15R @ 60Hz
+21.6C => Swiftech MCP650 @ 12.0v
+21.6C => Iwaki MD-30RZ @ 50Hz
+21.7C => Iwaki MD-30RZ @ 60Hz
+21.9C => Eheim 1250
+22.1C => Laing DDC @ 12.0v
+22.3C => Eheim 1048
+23.3C => Eheim 1046
Not a whole lot of performance difference between the top contenders. I would come down to price/availbility for me.
I would agree, if the MCP600 were still available, but it's not. The 650 seems right there with the 600, I'd say it's within the noise. I've got a month or so yet before I buy, so that gives me tiem to hunt for the Iwaki and decide.Jonsey said:From the link above:
mwarps said:I would agree, if the MCP600 were still available, but it's not. The 650 seems right there with the 600, I'd say it's within the noise. I've got a month or so yet before I buy, so that gives me tiem to hunt for the Iwaki and decide.
