Is 7075 considered a decent score?
you probably have AA/AF on, but the 6800 nu's dont usually get that high of scores :p
I guess the drivers is not well installed. Mine got half the normal score with 3dmark so i decided to clean the drivers in safemode then reinstall it. After doing it, scores went back to normal values.
idunno what i need to do to make my system work at its optimal level.. i have all the windows updates and the latest drivers for my video card, i installed the via 4in1's.. what else do i need?
google and download driver cleaner 3, clean out your nvidia drivers, then reinstall with
these drivers
http://www.nvidia.com/object/winxp_2k_66.93 if ur not runnin winxp or windows 2000, dont d/l this one
why? for me, they are more stable and i seem to be 1C cooler all the time now, compared to the 66.70's
My system is in my sig.
Except, instead of having an ASUS v9950 5900 Ultra Nvidia, I know have , when I ran the 3DMark03 program a- PNY GeForce 6800 GT OC @ Ultra speeds (415 Mhz Core/1.15 Ghz memory). Running everything at DEFAULT (not messing with the settings at all) I got around 12340.
Seeing those specs-
Athlon 64 3500 939pin, Abit K8T800 Pro, WD Raptor 36G, 1GB Corsair DDR400, Liteon 52x32x52, Logitech Z-640's, SB Live Platinum 5.1, PNY 6800 128MB, Raidmax Scorpio 868
I think your score is way too low...
setth84 said:
Is 7075 low for my computer in 3dmark03? specs below
I thought you were talking about '05, not '03. In that case, unless I'm overestimating the 6800, I'd say your scores are way low.
I'm running an Athlon XP tbred at 2.2GHz and an X800 at 500/500Mhz. You do the math.
