I heard there was a bug with the temp readings. But it was only like displaying about 20c more than normal. I dunno about 145.MalfurionStormrage said:I installed 71.84 and noticed that they added a temperature sensor in the nVidia control center. Is 145 C the real throttle down temperature for the 6600GT?![]()
I'm wondering the same thing. Also, is the NV Silencer much quieter than the stock Blue LED BFG dual fan HSF?astern said:It looks like my XFX 6800GT isn't as overly hot as I thought it was. (Idle @ ~60C and load at ~70C)
Would it be worth it to get an NV Silencer?
daragon said:I didn't know that nvidia cards had a temp sensor in them. How do you enable that, using MBM? but anyway, my temps sit around 33C with a water block on my proc, video and NB. I can touch the other side of the GPU(top), on a full load without it feeling hot. I would say that 60C is to high, unless I'm smoking crack and have no idea what 'normal' temps are.
ThomasE66 said:60°C is not even close to being too high for a Geforce 6 class GPU under load. If it goes much higher than the mid 70's I'd start to worry.
So my 66C idle temp on my stock 6800GT is because of the drivers and not the card? I remember the last time I checked the temperature is was around 53C idle (on 67.66, I believe).CrunkyMunkey said:I heard there was a bug with the temp readings. But it was only like displaying about 20c more than normal. I dunno about 145.
Could that also be the reason why RivaTuner won't let me OC my card to 400/1100? It was set there before
I have wondered the same thing, I just got the nv silencer 5 so I'll report back once I get it installed.Mojo said:I'm wondering the same thing. Also, is the NV Silencer much quieter than the stock Blue LED BFG dual fan HSF?
mickey987 said:My 6800GT under load is about 83*. I've tried overclocking the card by 1 MHz and it didn't drop anything.
After reading what ThomasE66 said...and looking at other ppl's temps I'm starting to worry. I have 4 case fans, I thought that, that would be enough cooling.![]()
Yup. My ultras load at about 72C.TheGamerZ said:60C is pretty darn low for a load temp.
poopypants said:I have wondered the same thing, I just got the nv silencer 5 so I'll report back once I get it installed.
sweet, CastleBravo how did u go about installing the cooler, did u lap it and what kinda paste did u use. i've heard that as5 works fine on the gpu and ceramique for the ram.CastleBravo said:I had the BFG 6800 GT OC with the 2-fan blue LED cooler, the NV Silencer 5 is WAAAAAAY quieter, and my card runs 10-15C cooler now (from mid 80s @ 370/1000 with stock cooler, to high 68s-low 70s overclocked to 400/1100).
Z(+)DIAC said:Noob Question alert!
I have the same card and have no idea how to check my GFX temps...what tool do I need to download in order to see such readings?
