Is 380w enough???
UberPooner
Hi, i was wondering if a 380w psu is ok for this build? (it comes with the case)
COOLER MASTER Centurion (comes with 380w psu) http://www.newegg.com/Product/Product.asp?Item=N82E16811119078
Western Digital Caviar RE WD1600YS 160GB 7200 RPM 16MB http://www.newegg.com/Product/Product.asp?Item=N82E16822136062
GIGABYTE GV-NX73T256P-RH GeForce 7300GT 256MB http://www.newegg.com/Product/Product.asp?Item=N82E16814125036
GIGABYTE GA-945P-S3 http://www.newegg.com/Product/Product.asp?Item=N82E16813128015
Intel Pentium 4 541 Prescott 3.2GHz http://www.newegg.com/Product/Product.asp?Item=N82E16819116231
If not, what should i use?
I'd pass on it.
Since you're on a budget, try the XClio goodpower 500w.
Get the case without the PSU, and go for either that 500W XClio Bbq recommended, or the 450W XClio.
