is 2.33 quad core equal to 9.32?
d3stiNy
Sorry if this is a stupud question but im looking to upgrade my machine. I am currently looking at getting either
This 2.33 quad core
or
this 3.0 dual core
I mean I am assuming that the quad core would be faster, but how much more would it get me, if at all?
And also just for personal information, does a 2.33 quad core equal 9.32 ghz?
Thanks in advance
No I am quite sure it is not. There is just so much information that can be received and sent by a processor.
It's kinda like saying "If I have two cars travelling at 50mph does that equal 100mph?" - it doesn't make sense.
Computing power isn't measured in Hertz, in the same way as it isn't measured by cache size.
Multiple cores will definately help in some applications that are designed to make use of parallel computing, but not all. So what are you using the computer for?
Go quad core and dont worry about anything else or look back. You could probably OC that quad core a bit too depending on your motherboard.
In an ideal world, your expectation would come true, subject to (at least) the following assumptions:
  1. Everything you run on your computer is perfectly multithreaded, in a way that would utilize all available CPU cores all the time.
  2. There is no overhead incurred when a task is distributed across multiple cores and the coordination between the processing in those cores are handled.
In practice, neither of these assumptions are true. Only some applications are multithreaded in a way that would allow them to run on multiple cores at the same time. And, technically, there's always some processing power that is spent on the overhead of distributing stuff across multiple cores, keeping it sync, and bringing the results back together, though it could be argued that the amount of this might be negligible in most cases.
^^^ /thread
there is no good reason to go with a dual over quad these days unless the price is keeping you from bying one (which isn't even that bad these days)
there is a benchmark called cinebench where you can compare multithreaded performance.
you'll find core i7>core 2 quad>core 2 duo.
even with insane overclocks, its hard for this hierarchy to be broken.
in general, get as much cores as possible.
To go along with the car example, the same amount of force required to accelerate two cars would get you far less than 100mph with one car with 100% scaling due to the increasing effects of wind resistance, friction, and internal mechanical resistances :p
Nice to know that my analogy stands up to the laws of Physics :p
I will mostly play blu-rays and the occasional game on this. I just upgraded my video card because it did not have HDCP, I believe it is called, and now I want to upgrade everything else:D
Also my video card is not being used to its full potential because of my 3 year old build if that gives me a better excuse...
Quad. Do it. i7 if you can afford it, C2Q if you can't. The Q6600 (used, since they want too damn much for them new now) is still a strong, strong chip. i7 920 is faster, but motherboards are much more expensive and there's about a $100 premium on the chip and $50 on the RAM as well.
To go along with the car example, the same amount of energy required to accelerate two cars to 50mph would get you far less than 100mph with one car with 100% scaling due to the increasing effects of wind resistance, friction, and internal mechanical resistances and the sheer fact that E=1/2mv^2 so a car at 100mph has twice the kinetic energy of the COMBINED 2 cars at 50mph:p
fixed. force != energy. And wind resistance is not the primary reason why 1 100mph car > 2 50mph cars
and yeah, get the quad, but no, 4 x 2.33 does not equal 9.32. This is because each thread can only run on one processor at a time. If a program multithreads very well, then you may start to approach the performance of a "single" 9.32ghz chip, but those instances are few and far between. Mostly just benchmarks.
Quad's are good, but if he is only watching HD movies and playing the occasional game, do you really think he needs an i7? ;)
This. There are programs out there (such as various 3d rendering engines) that are designed to thread, and will actually use 4 cores at 100% simultaneously. But for the vast majority of people this will never be the case. It depends what you're doing though. If I did nothing but gaming and int3rnets, i would take a 4.0 oc'd dual over a 3.4 oc'd quad (keeping in mind a probable i7 in the not so far future). However, that is my personal opinion, and is not my current circumstance either as with my particular usage a quad is a no brainer.
You obviously keep your systems for some time if you are just planning a build after 3 years. With that being said you would be better off with the quad as more and more software/games are making use of the extra cores. In years to come that shift in multithreading will be even more apparent.
Why limit yourself to what you do now when you don't know what you'll be doing later? The quad is a better choice.
There was an eBay computer listing claiming an 8-threaded 3.2 i7 was "a 25.6 GHz computer" or something like that ... lol eBay ftw
Ive got a better analogy.
hire 2 guys who work fast
vs
hire 4 guys who work at a medium pace (Adam Sandler reference)
4 guys are going to get the job done faster when you can spread the work out to keep all of them busy, but at any task where having more guys doesn't help and 1-3 would just be sitting around the water cooler, the faster guys would have been a big help.
