theshadow27
- Sep 7, 2004
i have a 1000 gph pond pump and i was wondering if i could use it for water cooling
it does have 1/2" fittings, and it runs off 120vac
theshadow27 said:i have a 1000 gph pond pump and i was wondering if i could use it for water cooling
This is another water cooling myth...thewhiteguy said:If you put a restrictive block on that, make sure you use really good hose clamps and get them VERY tight, or you'll likely blow a connection. That's a powerful pump for watercooling.
Turbokeu said:This is another water cooling myth...
It's not the flowrate of a pump that will blow a connection, but the head (or pressure).
You can have a 10000GPH pump, if it has only a 10feet head it will blow nothing...
CD![]()
Of course, I assumed this pump's heat is quite high simply because you can't obtain that much flow rate without it being much higher than any of the pumps normally used for water cooling.Turbokeu said:This is another water cooling myth...
A good WC pump (MCP600/AquaXtreme 50Z, DD4/MCP650, Iwaki) is rated for 10+ feets of head, and nothing gets blown even without clamps...weapon-- said:10 feet of head and nothin gets blown? there are major conflicts in that sentence... *rimshot please*![]()
lol...I was just having a little fun with the head/blown word usage.Turbokeu said:A good WC pump (MCP600/AquaXtreme 50Z, DD4/MCP650, Iwaki) is rated for 10+ feets of head, and nothing gets blown even without clamps...
CD![]()
Not really, most big pumps (ex. Eheim 1260 (670GPH), Sicce Suprema (980GPH), Sicce Mega Plus (1490GPH)) have only a max head of 8 to 11 feet, but have big (3/4" or 1") in- and outlets and higher power wattages.thewhiteguy said:Of course, I assumed this pump's heat is quite high simply because you can't obtain that much flow rate without it being much higher than any of the pumps normally used for water cooling.
Means max head is 15 feet...theshadow27 said:it says on the pump "for use up to 15 feet" what does this meen?
i think i will try it out when my WC stuff gets here before i put it in my computer. i have hose clamps (like the type on cars) for it alrready.
also- - it was desigend to be submerged...
