Irritating error when I surf
kandah
http://img106.imageshack.us/my.php?image=scriptfelek6.jpg
I get that error all the time when I surf and I have to click the yes "ja" button every time. Is there any way to turn of this report and or make it automatically accept so I dont have to authorize it every time?
It basically says "An error has been encountered in the script on this page" "do you want to continue running script on this site?" and then there is the yes or no option.
Thanks in advance for any help.
Go to Tools, Internet Options, Advanced, and look under Browsing. You'll see a couple options to disable script debugging...
But I'd run some spyware scans and such... you shouldn't see it that often unless you've got something screwing up the scripts on the pages you're visiting.
