Brahmzy said:Once iRAM 2 is out, I may do two in RAID0. I have access to that type of RAM on the cheap. 16GB of solid-state boot volume? Heck yeah. Vista might even fit on it.
I thought they were getting away from the PCI slot thing and getting into the 3 1/2 bay thing?
canislupy said:I already had the extra memory lying around so I picked one up to try it out.
Pro:
Fast swap file = nice!
Con:
Installed OS to iRAM kept losing registry config
RAM modules with heat spreaders do not fit well
Full height RAM modules cause the iRAM to cross into space of adjacent slot
Short RAM modules very expensive
Hard to find an open PCI slot in PCs anymore
And that's about as far as I got. As a matter of fact, I'm done with it... just no space in the eVGA 680i mobo when you go SLI 8800GTX w/ an X-fi (not that it'd fit in the X-fi's place even if I wanted, since it would contact the 8800GTX).
I would only buy iRAM 2 if:
PCI-Express x1 slot
8GB RAM Support
SATA 3.0G
RAM modules oriented so that full height modules don't cross into next slot space
Except the Iram2 uses DDR2LightningCrash said:Let's say the iRam 2 is $200
Then you pick up eight 1GB sticks of DDR, to the tune of $100 ea
LightningCrash said:I'd rather drop $2K into a nice SATA array (320gb drives are on sale lately) and have a lot of sustained transfer rate as well as capacity. But that's just me, and I love iSCSI
The iRam(2) is also solid state, just FYI.mjz_5 said:maybe solid state is the better way to go
http://www.dailytech.com/article.aspx?newsid=4962
check out THG review (i know, and i'm very sorry)
http://www.tomshardware.com/2006/09/20/conventional_hard_drive_obsoletism/
mjz_5 said:maybe flash solid state is the better way to go
yes, we have had that discussion before and it's clear that the iRAM etc. are not as fast as system RAM and that maxing the latter provides 'more' benefits...Lazn_Work said:With 64bit CPU's and OS's you would be much better off just putting that same RAM into system RAM.. then it could be used by programs directly, and you wouldn't need a swapfile.
Also, modern OS's cache frequently used files into RAM already, so again, system RAM should be maxed before you bother with solid state drives.
spectrumbx said:I wish iRam2 supported DDR1.
I guess I will get the iRam1 when I upgrade and move on to DDR2 so can make good use of my many gigs of DDR1.
I am using a 320GB SATA drive solely for swap file. The 4GBs in my VMware server aren't enough so VMware swaps a lot to allow more VMs.
The performance as-is is pretty good, but I am guessing it will be even better with the i-Ram.
That depends entirely on what you're doing with itLazn_Work said:For a VMware server, you should have more than 4GB of system RAM. Of course this means a 64bit cpu and OS to properly take advantage of the RAM.
Brahmzy said:It gets even bigger when I walk in my DataCenter, hehe.![]()
But no, I'm not trying to flex my e-member, I'm just havin' a ball playing with this stuff - I just got to put these 2 in, a few days ago! There are moments when I really like my job and this is one of those moments. Staying up, all through the night, all weekend, performing an Exchange migration, like say...this weekend?![]()
Those are times I don't like my job.
Anyway, off-topic again.![]()
Brahmzy said:This is what I've heard about the original i-RAMs - occasional corruption, entire data loss and general weirdness. Which is one of the biggest reasons I haven't gone there yet. Hopefully iRAM 2 is leagues ahead of the original in every way.
I would recommend an onboard controller. Ignoring SMART status is generally a Bad Thing to do - if a disk is dying, the controller should know and warn you about it right away. So addon cards generally require good SMART status from their drives, and since the iRam doesn't do SMART you can't use them.dssconsumer said:dear sir, do you know who is making add-on raid controller pci-e 4x or 8x. i have the areca 1210 and as you know this add-on card doesn't support the i-ram in any configuration because the s.m.a.r.t. feature. or if you know a forum that this can be discussed. thanks!
sdavids5670 said:I don't normally get to post on threads like this so it feels nice to have some input for a change. I have quite a bit of experience playing around with the iRAM card from Gigabyte...
I've been using a 4GB iRam as my C: drive for nearly 7 months now.mjz_5 said:Also, anyone with the iram 1 drive, how do u guys like em? Worth the cash?
sdavids5670 said:After playing around with the card, I think I've finally settled on the best use of the technology for my situation. Rather than swapping off the iRAM drive, I'm using it to store a golden master image of Windows 2003 Server. Since the image is static (never changes), I just created a backup copy before I started spawning linked clones. Now I just create linked clones off of it. I can boot several Windows 2003 Server virtual machines (using VMware workstation 5.5) simultaneously with barely a peep from my disk drives and they all boot ridiculously fast. Since the gm image never changes and all of the changes to the linked clones are done to files store on the regular disk drives, recovering from a memory corruption error on the iRAM drive should be relatively easy to do. If the data on the iRAM ever does get corrupted, I'll just have to restore from my original backup and everything will be back to normal (hopefully - haven't tested yet but the reasoning is sound).
