Red Squirrel
- Nov 29, 2009
I've been reading up on IPv6, and it seems they got rid of NAT?!
Now I realize NAT is not meant for security, but it does act as a very simple layer of security that is very easy to setup. Ex: most users can buy a NAT router, install it and be secure from outside connections. You don't need to worry about keeping a software firewall on each machine or making sure everything is patched.
Also, most ISPs only give you 1 or 2 IPs, so without NAT, you'll only have a few machines online. People like us may have 10, 20 maybe 50 machines at once which require internet access. NAT is great for this as they are still in their own network and separated from the internet.
Another thing, it's MUCH faster to connect to a local IP than an internet one. If each computer is to have an ISP assigned IP that means when you connect to a PC on your network you will be going through your ISP then back.
I guess you can still use IPv4 locally but would there be other options? Or am I understanding this wrong? If anything my biggest concern would be the fact that the number of systems you can have at home would now be governed by how many IPs your ISP is willing to assign you. Sure there will be tons of IPs to go around but it still wont stop them from limiting you or charging extra. There's plenty of bandwidth to go around yet we still see ridiculous caps, so they'll do the same here with IPs.
