Unless your have the money to blow on an IPS monitor, I wouldn't spend the extra money for one. If you are programming mostly a higher resolution would benefit you more then better clarity. I play games a lot as well and I don't see the need for that expensive of a monitor unless you are a video or picture editor.
I am pretty sure I am going with an IPS. Is it worth the almost double the cost for the 24" models over the 23" models?
i do have the money, but it's more of a wondering if it's worth the close to double the cost for an extra inch.
No the U2311H is a superior product to the U2410 at half the price.
http://www.tftcentral.co.uk/reviews/dell_u2311h.htm
For reading Glossy is probably the best as there is no screen door or dirty screen effect. The U2410 has harsh AG coating compared to most monitors which many say leads to eye strain.
If you have 500$ to waste on the U2410 you would be much better off getting any of the Eizo C-PVA panels like the EV2333/FS2331 or SX2262W (16:10 1920x1200) which have far superior image quality and use very little AG coating.
You sure don't like the U2410. I have the U2311(am very happy with it, no problem reading at all, just adjust "no squint" settings in Firefox), but am thinking of exchanging it for the U2410 because of 16:10 resolution.
BTW I had the VW266H. Nice big monitor with washed out colors and poorly designed, hard to get at connectors. Plus a very flimsy wobbly stand.
