IPS Glow: 27" Versus 23"
TheRaoh
Hey guys...
Forgive me ignorance, but I read once that the IPS glow intensity can be different depending on the size of the monitor.
Is this true? And if so, which is better, small or big monitors?
My surface pro has a lot worse glow than my Crossover 27Q and my Cintiq 24 is inbetween yet my iphone has the best level of glow out of the four.
From my experience it probably depends on the monitor.
NCX could give his learned answer though.
What I've heard is that IPS glow tend to be more noticeable in larger monitors.
Reason I'm asking is because of this Viewsonic monitor... It comes in two sizes (23" and 27").
VX2370SMH-LED and VX2770SMH-LED
I'm not sure which would likely have less IPS glow.
IPS glow is probably dependent on the quality of the panel. If it is something that really bothers you you'll probably either have to go used or spend more money to insure quality.
Like JayJapan I have a a Korean monitor with almost no glow whatsoever so at least on that front it is a gamble. Reason I suggest buying used is that you'll know for certain it has an acceptable amount of glow if you get good shots before buying. Friend has a Dell IPS with worse glow then my monitor.
