SO amazing they implemented that so well. It works SO well, just like teh music.bahula03 said:yup, it's just like with music, click the center button once and the time "scale" will come up, then use the scroll wheel to go where ever you want in the video, and then click the center button again and you're there
yea, it looks like whatever they are useing as a decoder takes some serious juce to get running.TSS Modder said:did you happen to noticed the rated battery life for videos is 2-3 hours?![]()
between that and the fact that its going to have to access the hard drive constantly. which really really eats up battery life.Unknown-One said:yea, it looks like whatever they are useing as a decoder takes some serious juce to get running.
i average at least 2.5 hours on mine....(7\) said:i haven't tested it or anything.. but i bet i couldn't watch more then 30min of video before i dies..the constant on backlight kills the battery as well..
TSS Modder said:i average at least 2.5 hours on mine....![]()
(7\) said:quite honestly i was wondering the same thing.. tho i have yet to watch a video from itunes/apple directly.. so maybe it has to do with the way the file is encoded.. bitrates and such
Erasmus354 said:My battery hardly lasts for an hour and a half on video if I am lucky, usually an hour or less for video. I was about to start a thread asking if that was normal or if I might have a bad battery.
Is this a good idea? Was wondering if I should do it.CodeRed said:I let the iPod run (without headphones) to drain the battery.
