Ok, so I know the iPhone 4 has two separate models, the GSM and CMDA. GSM will only work on GSM and CMDA on CMDA networks no matter if they're unlocked.
Now, I heard the 4s has the same bands built into one model. So an unlocked Verizon or Sprint iPhone 4s will work on AT&T or T-Mobile? I always heard you can't use them with each other, even if they're unlocked.
Then I read that the 5 works just like the 4, GSM on GSM and CMDA on CMDA only.
What about the 5s?
I've been reading and searching on google but everybody says different things. What's the correct answer for the 4s, 5, and 5s?
What about the 5s?
