- Apr 13, 2000
I've been using IPCOP for 4 years or so. So far so good.
I got a new Intel Atom board with DUAL LAN NIC's. Its a great small board, ITX size. One LAN is red, the other green. I have a wireless PCI card in there too, but its not assigned to any color interface.
I installed IPCOP on it using a thumb drive as the flash HD. Everything boots. In fact the routing works, I am using IPCOP right now to access the internet.
Well now here is the strangest problem I've encountered with IPCOP. Everything is installed and working. I am able to ping google, etc. However I can't access the web interface! Its https://192.168.0.1:445 .. I even connected a keyboard and monitor back to the IPCOP machine to get back to the linux command line. Under setup I choose 192.168.0.1 as the green interface IP.
I don't see whats wrong here. Everytime I try to connect it just stalls, in the lower status bar it says "Connecting to 192...." and then nothing happens. This is fucking annoying. WHY IS THIS NOT LETTING ME CONNECT? I even tried from two different PC's, I even tried using a cross over cable from my laptop to the green interface of the router. But same thing happens. I can't connect to the web interface on the default IP and port and using httpS. I even used IE and Firefox. Same result.
I tried to do an IP range scan of 192.168.0.1 to .255. But nothing is responding. Probably because green is blocking pings? But why on green side? I don't know anymore
Cliffs:
IPCOP is working
Even taking a cross over cable and directly connecting a PC to IPCOP green interface does not connect to web interface, yet I can still go online to webpages. I AM ONLINE.
Cliffs:
IPCOP is working
