Just run a cable from your Green NIC to one of the routers LAN ports and use the router as a AP, it can also double as a switch. If you want to get a little more fancy you can throw in another NIC and create a Blue zone which if i remember right is IPcops wireless zone (Seperated from the green zone)
Also disable the routers DHCP server as i imagine your IPcop is taking care of that now..
I have actually run a similar setup awhile back, you are going to want to disable the DHCP server in dd-wrt since the ipcop is handing out ips now, and you are going to want to plug into the LAN side of the router and thats pretty much it. Now why its not broadcasting a SSID is a different story, especially is you have SSID broadcasting enabled. Are you able to ping 192.168.1.2 from your desktop pc? This will verify that everything on the wired network is setup right.
I have to ask:
have you disabled the SPI firewall on the linksys (dd-wrt)
...Linksys is running the most current DD-WRT too (forgot to mention that in the first post)....
Check previous post of mineare you using a modded version of linksys ( openWRT,dd-wrt) ?
If not, try disabling the built-in firewall the linksys device has enabled by default.
I can't remember where it is off the top of my head, but if you dig around in the security tab, i believe you might find it.
FYI - SPI stands for Stateful Packet Inspection
If the cable is plugged into a LAN port of the wrt...SPI/firewall is totally irrelevant..you're NOT using the router feature..you're just using the LAN features..basically just using it as an access point. There is no flow through the NAT going from LAN <==>WAN. You're effectively not using any firewall features.
If IPCop is 192.168.1.1, make the wrt 192.168.1.245...disable DHCP on the wrt. Uplink the wrt to the green NIC of your IPCop box using a LAN port. DHCP will flow into it from the IPCop box.
I run this setup often between IPCop, Endian, ISA, RRAS, and/or whatever other router I'm using.
DD-WRT...disable internet connection. Also can flip the WAN port into a standard LAN port in DD-WRT...effectively making your wrt a 5 port switch.
So go from IPCop to Linksys, then Linksys to my switch?
If you need more than the 4x free ports you'll have on your wrt...yes...you can uplink to another switch.
Or if you're using a beefy switch with lots of nodes, or a giga switch for your LAN..uplink that to your IPCop box...and also hang your wrt off of the switch..again, using a LAN port of the wrt.
