ip35pro- broken motherboard or am I missing a setting?
masteraleph
I currenly have an IP35Pro. The problem that I'm seeing is that while 2 of the ram slots work (the two closer to the back of the motherboard), the front two don't seem to. This is now an issue, since I'm trying to run a 4x2GB setup for ram. Am I missing a setting or is it possible that two of the ram slots on this motherboard are broken?
As far as I know there isn't a setting to turn on/off ram slots in the BIOS. So if you alternate the ram slots when you're putting in the ram (slot 1 + slot 3), what happens? Just 1 stick shows up or does the mobo just not turn on?
If you ram sticks are fine then I would think there was something wrong with the motherboard. Especially if they work in certain slots and not in others. Because that kind of rules out memory timings, voltage etc.
running 4 DIMMs is more stressful than running 2 & may require you to increase some voltages e.g. the RAM voltage, MCH etc.
Hopefully you are running a 64-bit OS with 8Gb.
