Anyone else with an IP35-Pro notice that the sound output goes open when you reboot? It seems like until the sound card is initialized it's like the audio cable is unplugged (ie. some hum and noise coming out of the speaker).
Also, all the outputs other than the front left/right have an annoying hum all the time, even when the sound is initialized. If I plug in a subwoofer I can hear a faint hum (sounds like maybe 60 Hz) which is incredibly annoying because the subwoofer just amplifies it and the whole room has this dull buzzing sound. I tried mono and stereo output to the subwoofer with the same result. The rear channel outputs do the same thing with a constant faint hum/buzz. Doesn't matter what the volume is set to, I can mute everything and it's still there.
Any ideas? I'm really interested to hear if other IP35-Pro owners get the same thing or if maybe my board is bad.
