IP35 Pro: Is this my culprit?
Cproflow
Hello [H],
In short, my OC seems to be degrading, but with a fairly consistent pattern. The symptoms are lockups and BSODs. These can happen either at idle, medium load, or full load. Some history...
I started out at 3.6, and I was happy with that. Sure I would have liked to go higher, but overall, quite happy. Fully stable (24 hrs Orthos, OCCT). Vcore is 1.46 (pre-droop), temps great at 20C idle, 38C load. Stable for ~ 3 weeks, then all at once, lockups, BSODs. In the course of one day things started crumbling. Orthos fails within a minute. BIOS 11. Memtest checks out for several hours.
I clock down to 3.4 and get back to stable. Again low Vcore (~ 1.37 I think) and temps are great. Orthos 12+ hrs stable. A couple weeks pass...same symptoms. Stable then a sudden flurry of lockups/BSODs. BIOS 14. Memtest checks out for several hours.
Downclock again to 3.2...eventually the same issues. I go to (perish the thought) stock. Things seemed to stabilize there. I did not experience any issues at stock (ran stock for about 1 week). Memtest OK.
One weird thing happened though in my troubleshooting, all of a sudden my entire system shuts off...freaked me out really :eek: An alarm goes off on my now shut down APC UPS. I was thinking it was a little undersized for the job (550VA), so I went out and got a beefier UPS. The APC 1300VA/780 watt model. I thought I had it licked...as the UPS would draw ~50% at load now. Previously, my undersized one was probably near 100%! Eureka I thought!
I decided to ramp back up to 3.4, and things have been going great for ~ 3 weeks. Then yesterday...the cycle started repeating. I went to 3.2, and have also had a lockup.
In all cases, these lockups/BSODs can happen anytime...from idle, just surfing the internet, to gaming (particularly LOTRO). No pattern as to stress seems to trigger it, only a period of time of stability, followed by a rapid degradation in stability. I can go from 3+ hours of straight gaming, to a lockup as I'm looking at Digg.
I was thinking RAM may be the issue (hoping actually). I'm running at 2.2 Vdimm, as is the rated spec. Memtest checks out though (although Memtest doesn't catch everything).
I doubt it is the CPU, as I don't think I could have run those long Orthos tests and had it pass. Vcore has always been pretty low...never higher than 1.47 in uGuru.
I suspected PSU. The OCZ is not the best PSU, but it is far from the worst, and overall has never given me a stitch of trouble in the the other computer this build replaced. Never has the UPS given an under/over volting report. It has never reported any issues.
That leaves the mobo, although I don't know what it could be. I do know that it is running cool, as I replaced the TIM with AS5 on NB and Ceramique on the SB, kept the pad on the MOSFETs. I screwed down the heatpipes for optimal contact. I have a fan on the NB and on the MOSFETS. Temps are ideal.
So I'm stumped. Does anyone have any experience in this or could provide some tips or perhaps something I missed? This Intel build has been the easiest OC I've done, but I just can't get it stable, so obviously it stinks! :wink:
I'm just wondering if I should look to getting an RMA going. I hear abit's RMA process is just about the worst in the business, so I'm not looking forward to that. However, I will get it going if need be.
At this point, I just want to know what component is the culprit!
Thanks so much for bearing with me on this long post. I just wanted to get at much info in as I could, and answer any questions. This has gone on since I built this rig (~3 months)
Please help if you can, it is much appreciated!
What model CPU and what FSB/Multipliers are you running? If you're running a lower multiplier than stock you may have to turn off EIST, otherwise the CPU will step through the full range of multipliers available including the highest default multi, which means you weren't really lowering your clocks...
maybe its something really silly like dust in the HSF fins causing more heat build up. or the NB heatsink has a crappy thermal pad.
The CPU is an C2D E6750, running at stock muliplier of 8. My FSB will change based on the clockspeed I'm after. But as of now I'm trying to get 400 x 8 = 3200mHz stable. EIST is turned off.
I don't think it is poor contact at the NB...I have the heatsink screwed down with AS5 on it. uGuru shows temps to be ~ 30C idle and ~40C load
You will get conflicting info about that & it will also vary by country.
1 thing though that abit are is probably more open than most (e.g. as shown by the bad caps issue where every mobo mfr was affected but abit were the only 1 to stand up admit it & do something about it) & I'm sure that sometimes makes them look worse than others when in all fairness they aren't - e.g.you will hear nightmare stories about Asus RMA too.
You mention BSODs - what did they implicate?
