IP35 Pro hangs at 7F / CMOS checksum error
RiO
Hello people! I used to lurk here before but decided to join since I've encountered an issue with this board I can't seem to resolve... here's my story:
» The board worked great the first time I installed it in my Stacker (stock air cooling)
» Got it up and running on water (in the Stacker) but it would not boot - it would get stuck at a 7F error with no display either. I'd hit F1 to continue but the error code would change to 99 and then shut down after a few seconds.
» When I got past the 7F error finally, the system would sporadically shut down - sometimes during POST and sometimes in Windows. I gave up at that point.
» Set up my system outside the case (on water again) but it wouldn't boot into windows, sporadically shutting down. I removed the CMOS battery and left it idle for a couple days - after that, it booted up just fine and worked well for close to a week.
» Since all was good, I decided to move everything inside the Stacker again. I've encountered a different issue now that I have not been able to resolve - the system consistently gets stuck at the 7F error code and I get a display screen which has another error: "CMOS checksum error - defaults loaded" / "hit F1 to continue or DEL to enter setup". Funny thing is it appears stuck - hitting F1 or DEL doesn't help at all.
I've cleared CMOS and removed battery many times - nothing really helped. I also removed the battery for 8 hours and then tried booting but it still hangs at the same screen (cmos checksum error) and error code (7f). No matter what I try, I can't get to BIOS setup :(
Any clue?
I was afraid someone would say that... before I RMA I guess I'll try it barebone outside the case again. What if that works? lol
Might want to try a different battery just for the hell of it. Does sound like a screwed up BIOS chip though.
USB or PS/2 kb?
A full system spec would be useful as well.
Here's what I've tried with no further help:
1. Replaced battery with the one from my P5N32-E board.
2. Did a deep CMOS clear.
@BUFF, it's a PS/2 keyboard.
Full system specs:
Intel C2E X6800 | Abit IP35 Pro | 2GB Cellshock PC2-8000 CL4
2*80GB 7200.10 + 2*320GB 7200.10 | LiteOn LH-20A1P DVDRW
OCZ 8800GTX | ViewSonic VX2025wm 20.1" LCD
STACKER STC-T01 | OCZ GXS850 | APC SU750VA
yeah this happened to me 2
but on my old Pentium 4 mobo
i went to my comp tech
and he said you either have to reload your bios and see what happens
or buy new mobo
if i was you when you get it to boot normaly DON"T TURN OFF YOUR POWER
Did you ever flash the bios while it was working? You might have corrupted it, I'd try reflashing if you have and deffinately use bios 14 if its a revision 1.1 board. I guess theres a 17 too but I haven't tryed it. I'm not sure if flashing it is possible with your situation but it's something to think about.
It appears I've encountered every possible problem with this board lol... anyway, good news is that it's back up and running. I did a deep CMOS clear and restarted the PC at least 4-5 times holding the INSERT key and finally got to the BIOS setup... whew, what a ride.
After that, I rebooted and lost my DVI signal... had to switch to Analog, and when I fixed that my friggin keyboard stopped responding... fixed that just now and back on my main PC. I just hope I don't have any other problems today at least heh.
Thanks everyone for your suggestions...
they work fine
and they are a bang for your buck
which is a good thing
