IP35 Pro 3 pin CPU fan control
scamartist
Just built the system in my sig.
Heatsink for the CPU is an Ultra 120 extreme with a Noctua NF-S12 3 pin fan.
Is there a way to control fan speed for this fan without the 4th pin feeding back RPM?
Thanks in advance...;)
the 4th pin doesn't send rpm but is used for PWM control of fan speed.
The CPUFan header should be able to control a 3-pin fan but some people find that they get better results using 1 of the 3-pin headers (e.g. SYS or Aux) instead.
If you do that don't forget to disable the low rpm warning/shutdown on the CPUFan header first.
