2 Questions about the ABIT IP35-E motherboard.
I am running the EQ software that came with the motherboard.
- It says the CPU temp. is 27C when CoreTemp says it is 38C. I assume CoreTemp is correct?
- I am using Patriot PDC22G6400LLK ram. The default voltage setting for the ram is 2.04V (max) but my Patriot memory says 2.2V. It displays a warning. Is it ok to change the default to 2.2V max? What should I set the voltage to in BIOS? Why the motherboard does it set such a low limit?
Thanks.
Thanks.
