horseflesh
- Feb 25, 2005
Since the E8400s are hard to find I am thinking about the E3xxx Xeon version. Has anyone tried one in the Abit IP35-E?
USB support set to "by BIOS" ?- BIOS config would hang with a USB keyboard! Never seen that before.
It's a Windows problem - theree's a knowledge base article about it.- After installing the latest Intel chipset drivers from their site, the USB ports all died. They weren't even getting power. Apparently there is some kind of serious software conflict, I googled up many similar stories but no solutions. I rolled back with system restore and just didn't install the chipset drivers... but surely I'm going to be missing something.
that's EIST at work - if you put load on the CPU you should see it increase in CPU-Z.- cpu-z shows my proc at 6x mult and 2 GHz total speed. Windows itself sees it as a 3GHz proc.
